Discussion topic: Broadband down essex
Message posted on 17 Dec 2025 11:30 PM
Broadband down in Essex
saying could take days
meaning I can't work
have no tv or anything 😩😩
Broadband out?
Anybody else in Stanford le Hope lost internet?
Message posted on 17 Dec 2025 11:33 PM
Re: Broadband out?
Yes!!! Ours is out in Stanford hun
Message posted on 17 Dec 2025 11:34 PM
Re: Broadband out?
Yes we have
Message posted on 17 Dec 2025 11:38 PM
Re: Broadband out?
I thought it was just us, sky's checker indicates that everything is fine, it obviously isn't!
What on earth is going on?
Message posted on 17 Dec 2025 11:56 PM
Re: Broadband out?
Yes mine is too! The sky app said it was an outage for like 5 minutes but now says everything is fine but it still isn't working !
Message posted on 18 Dec 2025 12:09 AM
Re: Broadband out?
Ours says the same and says it could take days to fix! 😩😩
im supposed to be working! Clearly I can't
Message posted on 18 Dec 2025 12:10 AM
Re: Broadband out?
Yes mine too, checked my connection with sky and says all ok, but no internet????
Message posted on 18 Dec 2025 12:13 AM
Re: Broadband out?
Yep ours is out too!
Message posted on 18 Dec 2025 12:21 AM
Re: Broadband out?
Ours is down in SLH too.
Message posted on 18 Dec 2025 12:35 AM
Re: Broadband out?
Mine too, West Yorkshire
Message posted on 18 Dec 2025 04:48 AM - last edited: 18 Dec 2025 05:10 AM
Re: Broadband down essex
@Hollyann24
Yes, Sky usually quote 2 WORKING DAYS as a potential fix time due to the service level agreement in the UK between ISPs and Openreach for fixing a fault. Openreach claim to be successful within that timeframe in about 85% of cases.
Some repairs take longer, for example when a pole or cabinet has been damaged or Openreach / City Fibre need to dig the road up (after getting permission from the local council).
As the Essex issues started before midnight it's unlikely to be maintenance taking place.
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 18 Dec 2025 05:03 AM
Re: Broadband out?
You are in a totally different area. In view of the time you posted any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
