Discussion topic: Broadband not wprking
This message was authored by: Churchyboy24
Used the broadband checker on the app and it's showing everything as good, this is clearly not the cas3, none of our phones are connected, none of the tvs are connected, How is it showing as good when nothing is working?
Re: Broadband not wprking
@Churchyboy24
In addition~
▪️ Any engineer visit that’s required is still likely to be delayed due to the disruption from the recent storms.
▪️ This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
