Discussion topic: Broadband not working
Message posted on 19 Oct 2025 12:56 AM
Broadband not working, mysky saying there's no issues on the line or my area.
hub is showing amber on internet and voice
reset hub and turned off for 30 seconds but still not working.
is there a direct number I can call off a non sky mobile?
Message posted on 19 Oct 2025 01:35 AM
Re: Broadband not working
Same problem here. Checker says all OK but no WiFi devices connected. There are devices connected, I can log into the hub and it is saying broadband is disconnected and showing several devices connected. But not talking to the outside world. So how can the checker know what's happening on the hub? It can't and its giving false info!
Can't find any way of reporting a problem.
Message posted on 19 Oct 2025 01:39 AM
Mines the same in RCT. Think there's a general fault.
Message posted on 19 Oct 2025 05:11 AM
Not sure it would apply at a weekend but when there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
Otherwise you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
