Discussion topic: Broadband not working
This message was authored by Richargh This message was authored by: Richargh
Hiya,
So my husband is away so I can't call the sky help as account is in his name, but basically the internet is either really weak or just not working. This started this afternoon. I've tried troubleshooting online and reset the box, checked the lines, restarted it. But nothing. I may get 30 seconds of internet before it stops again. We have a sky glass as well so can't watch that.
All the 4 lights on the hub are on green, but nothing works. Any ideas?
 thanks in advance!
Re: Broadband not working
@RicharghIf you have the login details of the account, you can run the broadband test from the information below.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Richargh
Thanks for this. It just shows there is a problem with my hub, but then I go round in circles as it keeps telling me to check the same things.
@RicharghWhat does it tell you to do?
