Discussion topic: Broadband not working but equipment ok
Message posted on 08 Jul 2025 02:29 PM
Message posted on 08 Jul 2025 02:40 PM
Re: Broadband not working but equipment ok
@Bluebell44
If your broadband isn’t working use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
