Discussion topic: Broadband not working but checker says it is
This message was authored by: p202957
My broadband isn't connecting. My router has 2 orange lights. However when I've gone through the checker on the app, it says everything's fine. I've unplugged everything and re-connected it and it's still broken. How do I report the fault?
J79
Re: Broadband not working but checker says it is
You need to follow the steps here:
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for p202957
I've done all that and it says it's fine but it isn't. Is there someone I can speak to to report the fault? The only option is to come through to this message board.
J79
Have you tried both steps and not just the 1st one?
Avatar for p202957
Yes I have done both steps.
J79
You will need to call Sky
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
