Discussion topic: Broadband not good enough
This message was authored by: LisaM3
My broadband router is continuously dropping off. There is no adverse weather conditions, everytime I do a check it tells me me everything is ok when I'm looking at orange lights, this is now the second time I am contacting sky with the same issue and this is meant to be an upgrade from sky when my previous WiFi router did not have these issues. I stay in a one bedroom flat and do not have multiple devices. So disappointing to be paying for a service that is so poor and not working. I'm essentially paying monthly for something that doesn't work. I've rest my router before an engineer tells me to do that again.
Re: Broadband not good enough
@LisaM3
You do realise you're not contacting Sky about it on here? This is a customer led discussion forum where Sky customers are available to help other customers. You aren’t contacting Sky Customer Services by posting here.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
@LisaM3 What is the hub connected to for the main connection out, Master socket for a fttc connection or to a ONT for a full fibre fttp connection. What actual hub do you have from sky now! Link below about the hubs and lights.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Avatar for LisaM3
I was advised to do this by Sky hence why I thought I was speaking to a customer service agent who would be able help. I contacted them again and an engineer is coming out to assist 👍🏻
@LisaM3 About at the top off the community page lets you have the Idea what the Forum is all about! Hope your Engineer sort's all your issue's out if you have any.
Avatar for LisaM3
Turns out they have said there is a fault in the line so an engineer is coming out to have a look. It's obviously recently just happened as didn't have issues with previous router. Thanks for the help 😃
@LisaM3 Fault's can appear at any time for all kinds of weird and wonderful reason's.
