Discussion topic: Broadband not connecting as it’s a new installation
Message posted on
30 May 2025
08:47 AM
- last edited:
30 May 2025
02:04 PM
by
Nimbob
The password seems to be wrong
[Removed]
Moderator notes: removed personal info
Message posted on
30 May 2025
08:49 AM
- last edited:
30 May 2025
02:05 PM
by
Nimbob
Re: Broadband not connecting as it’s a new installation
New installation and the system says - the password is wrong
[Removed]
Moderator note: removed personal info
Message posted on 30 May 2025 09:11 AM - last edited: 30 May 2025 09:25 AM
@Khalid11 Do not be publishing your hub password or any other information on a Public Forum, couple off bits more info and someone will be all over your stuff.
Next to the 2 is the only standout could be a small letter l, or possibly a number 1, have you tried a varriant to see. if not hold the reset and reset the hub before you kick it all down with loads off device connections.....
