Discussion topic: Broadband keeps failing
This message was authored by: Mark5311
Broadband has gone off 3 times today, it just fails, I then get a slow flashing green light followed by red light. Then it starts again eventually. Tested it on sky app which states it's all working.... Even though it's not working!!!
Re: Broadband keeps failing
@Mark5311
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
