Discussion topic: Broadband keeps dropping out and when testing the signal it says everything is ok,
Message posted on 04 Feb 2025 10:12 AM
I keep having my broadband band signal drop out, I run the test online and it says everything is ok but it clearly isn't, there is no telephone number to call sky so fraustrated
Message posted on 04 Feb 2025 10:57 AM
Re: Broadband keeps dropping out and when testing the signal it says everything is ok,
@Debs641
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
