Discussion topic: Broadband keeps droping out between 7pm & 9pm everynight. Only had sky for 6 days!
Message posted on 11 Aug 2024 08:53 PM
Message posted on 11 Aug 2024 09:04 PM
Re: Broadband keeps droping out between 7pm & 9pm everynight. Only had sky for 6 days!
@Dans99991 What colour of router from Sky black or white?
Message posted on 12 Aug 2024 05:31 PM
White
Message posted on 12 Aug 2024 05:41 PM
@Dans99991Can you run this test the next time your internet drops so it can be picked up as a fault. Otherwise you will have to call Sky and report this is happening.
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
