05 Jul 2024 09:57 AM
Hi there.
it appears that my broadband / Wi-Fi drops signal every couple of minutes. With my iPad I have to disconnect and reconnect every couple of mins. I have done a test hopefully this might help you answer my issues
05 Jul 2024 10:09 AM
Same here
gettin really fed up with it
05 Jul 2024 04:27 PM
Posted by a Superuser, not a Sky employee. Find out more@sands2301Going by the router stats that have been provided your last drop of your connection was over 5 days ago, But also notice the raised noise margin on the router stats of 11.3 and does show that there is a problem with your line.
Have you spoken to Sky about this to see if you can get this sorted and get an engineer to come out.
07 Jul 2024 07:12 AM
Thanks for the advice Highlander I will try and contact Sky.
