Discussion topic: Broadband isn't working at all. No Internet light is amber and the voice light is amber. I have rest
This message was authored by: Kelly361
The broadband is not working. The Internet light is amber and also the voice light is amber. I have rest it twice.
This message was authored by: Kat445
Re: Broadband isn't working at all. No Internet light is amber and the voice light is amber. I have
My internet isn't working either amber voice light and amber internet light rest it and plugged it out and back in and still no look!
@Kat445 @Kelly361  you sre posting after midnight when Openreach, Sky and the other network operators do maintenance work which if you link works normally during the day you can assume was the cause of the loss of connectivity. The work needs to done sometime and the earlly hours are used as usage is at its lowest.
