06 Aug 2024 10:09 AM
Our broadband has been occasionally been very intermittent for the last few months. Usually what happens is that we have the intermittent issue, I get an openreach person to come out and they fiddle with the main box for the village and check our box and it works. Last time Openreach came out three weeks ago, he had a look at it and sods law it was fine at the time so he couldn't do much other than reset the box but he suggested we upgrade to Fibre which we are doing. Unfortunately that has meant that I cannot get an openreach person to come out and look at our current issues as "we already have an engineer booked". In the meantime, I've tried changing the channel, resetting the router to factory settings, Sky has sent out a new router and still we get no more than about 20 minutes of consistent internet connection from about 8am to 7pm (better in evenings although not always). I'm hoping someone on here will have a suggestion that will help me get to Friday while trying to work from home.
Can anyone help me please?!
I can't post a picture but below are my router statistics:
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 28570 32928 0 133694 1488495 00:05:25 LAN Up 6047985 4694397 14 1683767 26040 61:57:26 WLAN (2.4 GHz) Up 1526496 12708 0 1245 0 61:55:19 WLAN (5 GHz) Up 40151781 23205876 0 0 0 61:55:14
06 Aug 2024 10:48 AM
Posted by a Superuser, not a Sky employee. Find out more@Hbrazel When is fibre supposed to be put into your property?
06 Aug 2024 10:49 AM
On Friday, so 3 days time. I'm ideally just wondering if there's something I can do in the meantime. Everytime the internet cuts out it is the WAN port on the router statistics. I'm not sure what that means.
06 Aug 2024 10:52 AM
Posted by a Superuser, not a Sky employee. Find out more@Hbrazel That is the connection itself and Openreach will not come out if you are getting fibre installed within the next few days and with the change over these problems will just go away moving to FTTP.
06 Aug 2024 10:54 AM
Yeah I get that openreach won't come out but was just hoping there was something I could do to make it more reliable but if it's external then my hands are tied. Okay so basically I'm just going to have to wait it out as there's nothing I can do to make it more reliable.
06 Aug 2024 12:55 PM
Posted by a Superuser, not a Sky employee. Find out more@Hbrazel If the disconnections are happening only every so often and you have discounted that it is something in the property and it is external there is little that can be done with only 2 full days till your FTTP install.
I take it all wires have been checked and seated properly.
