Discussion topic: Broadband is rubbish
Message posted on 23 Aug 2025 06:27 PM
Message posted on 23 Aug 2025 06:30 PM
Re: Broadband is rubbish
@Rhianna+a And what are you seeing when it does that! The Forum is not sky just so you know! If you cannot say then do not guess!
Message posted on 23 Aug 2025 06:35 PM
Sky glass and the broadband isn't working. Sky is our new provider and it's not working! That's what I'm seeing! Unless you've got some helpful advice what is your point in replying?
Message posted on 23 Aug 2025 06:42 PM
@Rhianna+a
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
