Discussion topic: Broadband is not working fine
Message posted on 06 Oct 2025 12:07 PM
Message posted on 06 Oct 2025 12:27 PM
Re: Broadband is not working fine
@Yemisanusi
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
