Discussion topic: Broadband is dropping out over 20 times daily and landline has started ro cut off
This message was authored by Saraht23 This message was authored by: Saraht23
Hey
Can someone please help?
My broadband has been dropping out constantly for weeks and now my landlines has started to do the same.
Have checked everything and all is OK until obviously it drops out and lights go red!
Getting extremely fed up with the service now.
Re: Broadband is dropping out over 20 times daily and landline has started ro cut off
@Saraht23can you run the broadband test while the fault is happening and maybe it can pick this up and enable you to book an engineer.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Saraht23
Thank you for your reply. I have tried each time and it says there is a problem with my set up then it comes back on and goes back to normal! Only this week has the landline stopped working several times. So fed up as I'm not great with technology and never had this problem with my old supplier. Considering moving back to them now they are in my area as there doesn't seem to be an easy contact number for support with sky as they keep sending me back to online help which is no good and not the service I am paying for.
@Saraht23If you are being sent a text stay on the line after this it should drop you into the queue to speak to an advisor.
