10
Discussion topic: Broadband intermittet
This message was authored by feilte This message was authored by: feilte
A few days ago my connection started dropping intermittently. When I do an online check it says a problem has occurred and tests are unavilable. I live in west of Ireland
This message was authored by cookiemonsteruk This message was authored by: cookiemonsteruk Answer
Re: Broadband intermittet
@feilte
Your downstream noise margin is high and suggests a line fault and the single downstream line attentuation figure suggests you are on a copper line all the way to the exchange so probably no fibre to the cabinet available.
Can you "run tests" on your my sky app or sky.com account and post the info in "more about your connection"
It does look like you will need to call sky ireland tomorrow on 08.185.00.27.3
(Remove all the full stops)
@feilte
Are you able to post your hub stats
@feilte
There does appear to be outages in Galway city, Ennis, Limerick and Lixnaw
feilte
Router Statistics
System Up Time: 30:36:17
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time
WAN PPPoE 1265425 2514711 0 4872 7433 19:43:38
LAN Down 0 0 0 0 0 00:00:00
WLAN (2.4 GHz) Up 3519891 1771005 6 4812 3940 30:34:37
WLAN (5 GHz) Up 2937317 1271913 0 604232 39219 30:34:26
Broadband Link Downstream Upstream
Connection Speed (Kbps) 9213 670
Line Attenuation (dB) 39.5 20.5
Noise Margin (dB) 9.0 22.9
Poll Interval:
Seconds (at least 3s):
10
Set Interval Stop
@feilte
feilte
Thanks. No fibre available here. Tests won't work. Says no communication with hub then tests unavailable. I 'll phone Sky tomorrow
@feilte
Where 'bouts are you on the west coast ? Any off the areas i mentioned above?
feilte
No. Knock, south Mayo
@feilte
The nearest known outages then are Galway city , Mohill and Athlone
Do give sky a call tomorrow but get back to us if you don't have any joy and we can escalate it to Sky
feilte
No luck contacting Sky. Just a recorded message saying do the online checks myself (which don't work) No option to speak to real person. I am considering changing y broadband provider. Can you please help further? Thanks
Ray
@feilte
Keep logged onto the forum preferrably using a chrome browser
I've escalated your post via the community chat. This link explains how it works
Keep an eye out for an invite or blue chat bubble. When the blue bubble does appear you have 48 hours to respond or it will be automatically closed.
