17
This discussion topic has been answered Discussion topic: Broadband installation via existing phone line
This message was authored by: BURKEY54
Hi
My Son has just moved into a flat & needs broadband as he's using his phone data & it's costing quite a lot.
The flat has a phone line, I've not tested it yet, been told it works by the landlord, I've a friend who has an old phone I can test it with.
I thought I would be able to sign up for a deal, a router would be sent out, connect it to the phone line and that would be it, without the need for an engineer visit.
Sadly, this doesn't appear to be an option.
Can someone advise what the engineer would be doing, as any alterations/drilling, need to be approved by the landlord beforehand.
Gareth
This message was authored by: cookiemonsteruk Answer
Re: Broadband installation via existing phone line
@BURKEY54
@BURKEY54 wrote:
Thanks for all the help guys.
He needs broadband for work, Netflix & gaming so what would be the best minimum?
Hard to say netflix uhd with dolby can take 30-35 Mbps.  Also does he download a lot of games.  Personally ihave 100 Mbps  with netflix uhd dolby vision and any games have been downloaded overnight .  Start at 100-150 Mbps he can always upgrade
@BURKEY54
If the phone line still worked then the previous tenant or the landlord haven't cancelled the previous broadband subscription which will need doing first.
Avatar for BURKEY54
I'm not aware of any previous broadband contracts for the flat, just told there was a connection there, I'm assuming just meant there was a working phone line.
Would the engineer have to make much alterations/do much drilling etc?
@BURKEY54
We'd need to see the two lines below the table in order to know if there's going to be an FTTP installation.
Avatar for BURKEY54
@BURKEY54
We would need to see the notes below the table as well
Avatar for BURKEY54
Full fibre with an overhead feed from telephone pole to house .  A new fibre cable will be installed on the day of activation.  Any copper line or lack there of is immaterial as the phone plugs into the sky roouter
@BURKEY54
Just checking that you entered your sons address or yours
@BURKEY54
Just asking in flats  that normally shows MDU  not single dwelling unit
Avatar for BURKEY54
It's one of four upstairs flats within that address.
Why can't we just plug a router into the existing phone line?
This is how my Fathers broadband still operates.
As you can tell, I'm not well versed in this stuff...lol.
Is it much work for the engineer?  How much of a mess will be made?  As it has to be run past the landlord...
@BURKEY54
When full fibre is avaiable openreaclh will not use the existing phone linex ..  let me double check your other images
@BURKEY54
It looks like every flat takes its fibre directly from the telephone pole so theres no central comms room.  For example i am in one of 25 flats  which are multiple dwelling units and landlord permission was required  but it appears for you you would not need o inform them 👍
Avatar for BURKEY54
Landlord now says go ahead and previous tenant had broadband so I don't know...lol
@BURKEY54 What was previous was ok, what is now is NOT ok, Fibre only so has to be upgraded, at the end off the day it is an asset to the landlord, free of charge to them, but you have to deal with it all.!
