30 Dec 2022 09:45 PM
Good evening. I'm with Sky Broadband and have gigafast but as per the hub is dreadful, I've had 2 engineers confirm that the hub cannot deal with the speed going through it currently and so performance wise I'm struggling.
I'm thinking of purchasing my own 3rd party router to use instead of the sky hub and am just looking for some advice or if anyone else has gone down a similar route?
Thanks in advance
31 Dec 2022 09:42 AM
Posted by a Superuser, not a Sky employee. Find out more@Danny69 If you do a quick search of this forum you'll see numarous posts about the same subject there are many recommendations already posted.
02 Jan 2023 11:17 PM
Hi pal. Happy New Year. I tried looking but couldn't quite see what I needed.
thanks for the reply pal.
03 Jan 2023 01:56 PM
Posted by a Superuser, not a Sky employee. Find out moreAny router that has DHCP Option 61 authentication capability. The Asus AC & AX line are a good example
03 Jan 2023 02:29 PM
Thanks pal
