Discussion topic: Broadband has gone down at 01:30AM for two days running.
Message posted on 03 Feb 2025 02:20 AM
Apparently a presumably multi-billion dollar company can't quite scrape the money together to have a single employee to talk to.
Broadband was down for 12 hours yesterday—essentially 01:30am until 13:30pm. Suspicious, exactly on the 12 hour mark.
It has just gone down again, and as per last night. I expect no message/notification will be sent out until 09:00am when the office crowd arrive to discover everything is broken again. Nobody to talk to, no acknowledgement of the issue and no reasonable compensation for loss of earnings. Will likely switch providers and dissuade others looking to avoid this mess.
Message posted on 03 Feb 2025 05:42 AM
Re: Broadband has gone down at 01:30AM for two days running.
Depending on who you switch to the issue could still be present if you change to an Openreach line based company.
What were the results of the lines tests that you can run:
Message posted on 03 Feb 2025 05:43 AM
@TolleyBT
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
There is no compensation scheme for loss of earnings for what is a domestic service.
