31 May 2022 08:43 PM
Hello,
My internet will always disconnect when it's raining. Happens everytime without fail.
It also randomly disconnects daily, no idea why.
Do I need to book an engineer to take a look?
Router stats:
31 May 2022 08:47 PM
Posted by a Superuser, not a Sky employee. Find out more@AlexC26Have you ran a broadband test to see if you can book an engineer?
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
01 Jun 2022 08:56 AM - last edited: 01 Jun 2022 09:18 AM
Posted by a Superuser, not a Sky employee. Find out moreAs I've remarked in other posts, typically the problem with that kind of fault is its intermittent nature means it may not manifest when Openreach attends, so it's worth considering the weather forecast when trying to get an appointment booked.
