Discussion topic: Broadband get disconnected for few minutes every 2-3 hours
This message was authored by: Gabriel42
Message posted on 19 Dec 2024 03:25 PM
Every 2-3 hours internet goes down, the box indicates a steady orange light on internet for 2-5 minutes.
its quite upsetting, would there be any way to fix it?
Find out more
Message posted on 19 Dec 2024 03:33 PM
Re: Broadband get disconnected for few minutes every 2-3 hours
@Gabriel42 it is most likely a line issue causing loss of connection. Pretty common issue on older partial fibre lines as water causes issues after bad weather. Whether Sky can get Openreach to do anything depends on the severity as the automatic systems should stabilise the line in time.
