Discussion topic: Broadband engineer - do i need him to come?
This message was authored by: Talia0
I just bought sky wifi and I belive the engineer option is automatic unless I missed a button when applying. Do I need them to come? My last wifi was easy to connect and I did it all myself, is the sky broadband any different? If I press to cancel the engineer will it just make me reschedule or is it possible just to get the box sent alone?
THANK YOU
Re: Broadband engineer - do i need him to come?
@Talia0
The area might have been upgraded to fttp. What are you on at the minute ?
Could you enter your full address below and post the table and notes after removing your address from the image
Avatar for Talia0
@Talia0
Wbc fttp shows full fibre is available
What speeds were you getting were you initially using a standard mastersocket? who were you with for broadband?
Avatar for Talia0
Before I was with NowTV but since im moving flat im changing. I think I got the Ultrafast one? If its just a box that needs plugged in surely I can do it myself. I just dont want to risk cancelling just to have to reschedule or pay a fee
@Talia0
Was that table for the new address?
Is there a fibre box already in place at the new address
@Talia0
Ah, the notes make no mention of an existing ont so yes an engineer needs to attend to install a new ont.
Avatar for Talia0
ah thats annoying booo
Thank you lots tho !!
@Talia0
Just to give you advance warning the mention of L2C indicates that a specialist crew using a cherrypicker may need to attend as they can't securely attach a ladder the the wall so this may extend the activation date .  Prepare for an even bigger BOOO
Avatar for Talia0
URGH
ahahahah thanks for the warning 😕
@Talia0
Aye.  Usually its because of cladding on walls which would not securely hold a ladder or its a listed building and openreach would not be allowed to bolt a ladder to the wall
