Discussion topic: Broadband drops out, thid is an on going issue that never seems to be repaired fully
Message posted on 16 May 2025 11:27 AM
As sbove
Message posted on 16 May 2025 11:36 AM
Re: Broadband drops out, thid is an on going issue that never seems to be repaired fully
@Isin
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
