Discussion topic: Broadband drops out from mid afternoon
This message was authored by JCD75 This message was authored by: JCD75
We're on fibre broadband and it was great for a while.
Now from about 3pm, when the kids start coming home from school in the area.. The connection starts dropping from anything to a minute to 20 minutes.
It's annoying when I'm trying to catch up on work as my work is done using software online. The kids want to watch something on Netflix and they can't.
All Sky do is blame Openreach. Who come and can't find a fault.
Any help, would be really useful and thanks in advance.
Re: Broadband drops out from mid afternoon
Hi @JCD75
Please post your router stats
I am NOT a Sky Employee
JCD75
@JCD75
So your stats suggest there was a line drop 22 hours ago. Additionally you have pretty odd speeds, it looks like your line has been banded due to a fault, either dropping line or errors on the line.
What happens when you run the line test on the My Sky app? It should allow you to book an engineer
@JCD75
Your speed is 39Mbps and your line attenuation shows its capable of 75-80Mbps and sign of line drops
Can you run tests from my sky app and post the info in more about your connection
JCD75
Yes Sky app says need an engineer as line fault. Openreach call and say there is no fault so just a vicious circle.
Re: Broadband drops out from mid aftedrnoon
@JCD75
For clarification what did it say about your minimum guaranteed download speed?
JCD75
JCD75
@JCD75
You are getting 39Mbps and guarantee is 51Mbps. The is a fault that needs investigated
@JCD75
Just curious openreach don't ring customers. Did you try to book online?
JCD75
When you book an engineer - Sky have been sending openreach as the fault they have is outside the house.
Sky blame Openreach and then vice versa. You just need to assume they will sort it.
JCD75
Thank you Cookiemonster and James for help. I'm not speaking to Sky. 🤞
