Discussion topic: Broadband dropping out
This message was authored by: EMJOliver
For a few months now my broadband has randomly dropped out, and comes back again a few minutes later after it males me sign into the WiFi again on all devices!
Tonight it has dropped out and I cany seem to get it back. Box has the 2nd and 4th light on orange, which means a problem with connection but the app says my connection is fine.
What do I do?
I am growing really tired of this **bleep**.
Re: Broadband dropping out
@EMJOliver
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband still isn’t working after 7am and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
