Broadband dropping out but router lights green
Researcher
Post 1 of 18
Hi,
I saw a post about this from 2014 but nothing more recent.  Several times a day my broadband stops working.  The lights on the router all stay green and the network connection icons on my laptops all show that they can connect to the router and there are no exclamation marks which would indicate no internet access but if I'm streaming or seaching the web or on a Skype call it's obvious that there's no internet connection.  The drop outs last for about 5 minutes and then it starts working again even if I haven't reset the router.  Before I had Sky I was with Plusnet and never experienced this, this has only happened since I've been using Sky.
I wondered if anybody else has experienced this issue and managed to get a resolution?
Camera Assistant
Post 2 of 18
Re: Broadband dropping out but router lights green
@Mardavila
Could you post your router stats for us?
And could you also post the routers 'Support log' when you next notice the issue happening?
Researcher
Post 3 of 18
Thanks for responding so quickly.
Here are the stats;
I'll have to work out how to get the support log but I'm sure that's on here somewhere
Thanks!
Router Statistics
System Up Time: 07:13:02
PortStatusTxPktsRxPktsCollision PktsTx b/sRx b/sUp Time
WANPPPoA31360604288494010029184882407:11:19
LANDown0000000:00:00
WLAN (2.4 GHz)Up2798987141588606052932543007:11:33
WLAN (5 GHz)Up28800492430829069957007:11:33
Broadband LinkDownstreamUpstream
Connection Speed9851 kbps1116 kbps
Line Attenuation41.0 dB27.2 dB
Noise Margin5.9 dB7.7 dB
Researcher
Post 4 of 18
I've got the support log now as well.  It happened a few times this afternoon.  I didn't make a note of the time so I'm not sure if it coincided with the 'send out NTP request' entry.
Jan 1 00:00:08 syslog: BusyBox v1.17.2
Jan 1 00:00:08 syslog: plc0 (Int switch port: 4) (Logical Port: 4) Link UP 100 mbps full duplex
Jan 1 00:00:19 syslog: [ 19.739000] Line 0: xDSL G.994 training
Jan 1 00:00:21 syslog: [ 21.742000] Line 0: ADSL link down
Jan 1 00:00:38 syslog: sky dhcpc client (v0.0.1) started
Jan 1 00:00:38 syslog: [ 38.753000] Line 0: xDSL G.994 training
Jan 1 00:00:55 syslog: [ 55.756000] Line 0: ADSL G.992 started
Jan 1 00:01:00 syslog: [ 60.767000] Line 0: ADSL G.992 channel analysis
Jan 1 00:01:06 syslog: [ 66.771000] Line 0: ADSL G.992 message exchange
Jan 1 00:01:07 syslog: [ 67.775000] Line 0: ADSL link down
Jan 1 00:01:09 syslog: [ 69.778000] Line 0: xDSL G.994 training
Jan 1 00:01:26 syslog: [ 86.781000] Line 0: ADSL G.992 started
Jan 1 00:01:30 syslog: [ 90.792000] Line 0: ADSL G.992 channel analysis
Jan 1 00:01:36 syslog: [ 96.796000] Line 0: ADSL G.992 message exchange
Jan 1 00:01:37 syslog: [ 97.948000] Line 0: ADSL link up, Bearer 0, us=1116, ds=9851
Jan 1 00:01:37 syslog: [ 97.953000] Line 0: ADSL link up, Bearer 1, us=0, ds=0
Jan 1 00:01:43 syslog: PPP LCP UP.
Jan 1 00:01:43 syslog: WAN link UP.
Jan 1 00:01:43 syslog: Received valid IP address from server. Connection UP.
Jan 1 00:01:48 syslog: Connection Up. SNO/MAC/IP/SWVER: [B220182B002996/24A7DC9F4DB8/90.192.114.163/2.07.2356.R]
Jan 1 00:01:48 syslog: Send out NTP request to ntp1.isp.sky.com
Jan 1 00:01:48 syslog: Time has been set from ntp1.isp.sky.com
Jun 29 11:40:10 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
Jun 29 13:59:16 syslog: Send out NTP request to ntp1.isp.sky.com
Jun 29 13:59:16 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
Jun 29 13:59:16 syslog: System time is up to date
Jun 29 16:14:22 syslog: Send out NTP request to ntp1.isp.sky.com
Jun 29 16:14:22 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
Jun 29 16:14:22 syslog: System time is up to date
Jun 29 18:41:26 syslog: Send out NTP request to ntp1.isp.sky.com
Jun 29 18:41:26 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
Jun 29 18:41:26 syslog: System time is up to date
Camera Assistant
Post 5 of 18
@Mardavila Nothing seems too strange from your router stats. Although I see your router has only been up for 7 hours, did you do reboot the router yourself?
The support log is located in similar location to the router stats you posted if you click the 'Support' tab instead of the 'Maintenance' tab you'll see the support log
Camera Assistant
Post 6 of 18
Ah okay I see you have found the log now.
So from the log there doesnt seem to be much wrong either. Can you explain any error messages you get on internet browsers when the internet connection seems to drop out? It may have something like DNS lookup failed?
Researcher
Post 7 of 18
From memory the error messages are the same as you would get if you were trying to use the internet with you're router switched off; no internet connection, skype requires log in details.  I'll have to wait until it happens again to confirm if they're exactly the same.   I just read somewhere that it might be something to do with my mobile phone but that doesn't seem to make any sense to me.
Camera Assistant
Post 8 of 18
Are the devices wired or on WiFi?
Researcher
Post 9 of 18
All Wi-fi
Researcher
Post 10 of 18
Same here, don’t notice it as much on WiFi. But on Ethernet you have to go to the device and switch the Ethernet setting off then on again. Lasts about 20min and happens again
Camera Assistant
Post 11 of 18
@Mardavila Give a device a go on ethernet to see if it still happens then we  may know if the router is faulty or there is something wrong with the WiFi
Researcher
Post 12 of 18
Will do, cheers
Researcher
Post 13 of 18
Hi,
I had exactly the same issue, I had to get in touch with sky and they sent a tech out to replace my router and install some boosters.
my advice, get an engineer visit booked in ASAP
all the best and take care 👍
Researcher
Post 14 of 18
I sourced a cat 5 cable but the drop outs are happening exactly as before.  So seemingly not an issue with wifi.
I think I'll take madicks advice and get onto Sky.
Thanks everyone for trying to help out
Researcher
Post 15 of 18
If you register with the ‘my sky’ app, you don’t have to wait in a queue and can request a visit by the messaging service in the support (fix a problem) section 👍
let us us know how you get on, hope it’s fixed soon Smiley Happy
Recommended Threads
Laconnor 19-06-2018 08:00 AM
4 weeks ago 02:50 PM
23-02-2018 11:07 PM
Broadband+issue12 09-05-2018 11:33 AM
01-06-2018 04:17 PM
