Discussion topic: Broadband dropping in and out
Message posted on 05 Feb 2025 08:52 AM
Since yesterday my broadband keeps disconnecting and reconnecting again after 30-60 seconds.
Orange light on the box for internet and voice.
I've ran the service checker but each time it reports back with no issues. I've seen a few posts with these issues.
Message posted on 05 Feb 2025 03:57 PM
Re: Broadband dropping in and out
Ours has been the same. Had no issues for almost 12 months and now it is randomly on and off.
Message posted on 05 Feb 2025 04:02 PM
@DCR7
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
