15 Apr 2023 11:36 PM
1970 00:00:21 syslog: [ 0.188000] brcmboard registered
1970- 00:00:38 syslog: [ 35.063000] Line 0: xDSL link down
1970-01 00:00:39 syslog: [ 38.066000] Line 0: xDSL link down
1970-00:00:45 syslog: Voice Disconnected
1970- 00:00:49 syslog: Voice Connecting
00:00:55 syslog: [ 50.066000] Line 0: xDSL link down
1970-January 00:00:55 syslog: [ 52.066000] Line 0: xDSL G.994 training
1970-January 00:00:58 syslog: Voice Disconnected
1970-January 00:01:09 syslog: [ 66.066000] Line 0: VDSL G.993 started
1970-January 00:01:19 syslog: [ 78.066000] Line 0: VDSL G.993 channel analysis
1970-January 00:01:20 syslog: [ 79.303000] Line 0: VDSL2 link up, Bearer 0, us=19999, ds=76802
1970-January 00:01:20 syslog: [ 79.303000] Line 0: VDSL2 link up, Bearer 1, us=0, ds=0
1970-January 00:01:24 syslog: sky dhcpc client (v0.0.1) started
1970-January 00:01:51 syslog: ptm0.1 - WAN link UP.
1970-January 00:01:51 syslog: Received valid DHCP lease from server. Connection UP.
1970-January 00:01:52 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [/redacted
1970-January 00:01:52 syslog: Send out NTP request to ntp1.isp.sky.com
1970-January 00:01:52 syslog: Time has been set from ntp1.isp.sky.com
2023-Apr 15 19:34:18 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
2023-Apr 15 19:34:22 syslog: TR69: Connect to Production ACS
2023-Apr 15 19:34:22 syslog: TR69: Connection to ACS Complete
2023-Apr 15 19:34:25 syslog: bind 0.0.0.0 - Address already in use
2023-Apr 15 19:34:34 syslog: WAN IPV6 UP
2023-Apr 15 19:34:34 syslog: Voice IP Connection Up: redacted
2023-Apr 15 19:34:35 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: redacted
2023-Apr 15 19:34:35 syslog: TR69: Voice Line SIP configuration received
2023-Apr 15 19:34:36 syslog: TR69: Close ACS Connection
2023-Apr 15 19:34:38 syslog: Voice Disconnected
2023-Apr 15 19:34:42 syslog: Voice Connecting
2023-Apr 15 19:34:42 syslog: Voice Connected
2023-Apr 15 19:35:09 syslog: The user with IP address 192.168.0.2 has failed to log in.
2023-Apr 15 19:36:05 syslog: The user with IP address 192.168.0.2 has failed to log in.
2023-Apr 15 19:36:08 syslog: Administrator login successful from IP: 192.168.0.2 .
2023-Apr 15 19:41:09 syslog: Administrator logged out from useragent:User-Agent
2023-Apr 15 20:04:25 syslog: WAN IPV6 UP
2023-Apr 15 20:08:42 syslog: Lease renewed 3600 ip
2023-Apr 15 20:34:25 syslog: WAN IPV6 UP
2023-Apr 15 20:42:36 syslog: Lease renewed 3600 ip redacted
2023-Apr 15 21:04:25 syslog: WAN IPV6 UP
2023-Apr 15 21:06:04 syslog: Administrator login successful from IP: 192.168.0.2 .
16 Apr 2023 07:45 AM
Posted by a Superuser, not a Sky employee. Find out more@alcaprone thst log is normal for a reboot of a Sky hub. If your hub is rdbooting spotaenously there is a fault - when this happens you will see lots of sctivity on the inicator lights and the connection takes up to 5 minutes to re-establish.
Its worth checking the power supply as dodgy mains will cause reboots otherwise call Sky to get the unit replaced.
