10
This discussion topic has been answered Discussion topic: Broadband down, sky say no!!
This message was authored by: M_Moore
Broadband down, router was just flashing. It's a new router too, went down at midnight but when I checked my sky app Sky say there is no problem, judging by all the comments Sky have more than a technical issue if they don't know when it's not working!!
Re: Broadband down, sky say no!!
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
Is it's not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
This message was authored by: MSSHARP
Service is pathetic!!
WiFi is down, and as you Sky say everything is working ... what the hell !!
I am trying to work, and can't even speak to a human on an emergency number !!
[removed]
Moderator Actions: Removed inappropriate comments
Avatar for M_Moore
Mines only just come back on. The crazy thing is the app says check your Wi-Fi! 🤦‍♀️
This message was authored by: Mojo9
Same problem here.
Broadband & WiFi test come back "all good and working"... will it was all switched off !!!
still not working. Internet light Amber.
and cannot find a way to contact Sky directly on the app.
this is pretty bad !!!
This message was authored by: ChrisMc01
My Sky says Broadband working which is a lie. My router says it's not and my phone is using G4. Will call to call in the morning. Been out at least half an hour.
This message was authored by: Cree68
My sky Broadband is down too, booked an engineer to come out and earliest appointment I can get is 10 days away.
That is some service, thanks guys
@Cree68 Can be the delay due to time off year and current conditions!
This message was authored by: KJ22
its the worst service and bottom of the table for , the issue of broad signal dropping with amber lights every month and being on the phone holding to book an engineer visit. this is the 6th time this year that I have the issue returning. SKY is the worst service provider now. I reckon its time to move. I sick of dealing with these guys!!!
@KJ22 Take it that it's been the same since your last posting, was there anything done regarding that or are you just running down the leave time? The request from then still stands as on the other post unless you have been informed!
since my last post. the engineer visited early Oct (for the 5th time since March) and everytime a new issue was raised i.e. communal box fault / part faulty etc the usual excuse for the recurring issue. and this time around, i have had enough!
