Discussion topic: Broadband down EX39
This message was authored by: JoPatrick1
Broadband down EX39
Hi, so the WiFi has gone down in my home again for the 5th time this weekend, yet when I'm doing the speed test, it's saying everything is looking good? Clearly not as there's an orange light on the box
Re: Broadband down EX39
@JoPatrick1
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
