Discussion topic: Broadband data usage
This message was authored by mkhan155 This message was authored by: mkhan155
Was just wondering if there's anyway to check which devices were connected in the last month and how much data they used. This is because a couples Months ago I used 500gb and the previous was 2.2GB. Quite a large jump so I'm thinking someone else could be using my WiFi? Thanks in advance
Re: Broadband data usage
@mkhan155Don't think that there is anyway to check which device(s) have downloaded data via the router or the app.
You can check which devices are connected to the network via the app at the time in taking the broadband test.
@mkhan155
Could have just been a one off month where you downloaded a lot of TV shows or some devices did lots of updates. Or perhaps a game update on a console/PC?
I am NOT a Sky Employee
mkhan155
@jamesn123
quite a large amount. Don't think ive ever been above 700gb even in lockdown. The sky hub stats show a lot of unknown devices. The sky tester should pinpoint the devices better I'm guessing ?
No, it doesn't detect or log individual devices. 'Unknown' just means a MAC address lookup hasn't identified a device manufacturer: it doesn't imply the hardware isn't known to you.
