This discussion topic has been answered Discussion topic: Broadband contract renewal
Message posted on
18 Jun 2025
09:01 PM
- last edited:
02 Mar 2026
08:20 AM
by
SpaceSparkie
I need to speak to someone (not a bot) about my out of contract broadband/talk/landline contract. The link sky sent is broken [content removed]
Moderator note: language removed
Moderator note: Title change to reflect issue
Message posted on 22 Aug 2025 02:17 PM - last edited: 22 Aug 2025 02:20 PM
No need for two thread @Susanhann so I've merged them.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
Message posted on 18 Jun 2025 09:02 PM
Re: Sky customer service phone number
@ksy
To call Sky dial 150 (free) from either a Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The forum filters don’t allow the posting of full phone numbers on here.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Message posted on 22 Aug 2025 02:05 PM
I need to talk to customer service
Message posted on 22 Aug 2025 02:16 PM
No Wi-Fi
I have no Wi-Fi connection
Message posted on 30 Nov 2025 11:40 AM
I wont to speak to human not bot
Message posted on 30 Nov 2025 11:42 AM
@Karen283 The contact options have been posted above please take a few minutes to read the replies.
Message posted on 30 Nov 2025 11:43 AM
All calls will start automated (aka 'the bot') which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
Message posted on 04 Dec 2025 05:36 PM
How in the name in hell, can you get past that dam chatbot & talk to someone at sky, when you have an problem with their products? Any help would be great, rather than calling them on a number that costs me money, to sit be told to wait & wait for a person!!! Grrrrrrrr
Message posted on 04 Dec 2025 05:37 PM - last edited: 04 Dec 2025 05:55 PM
See the second part of my earlier post (post number 5) and post 8.
Message posted on 09 Dec 2025 10:57 AM
Just put the actual number in the post not a series of pointless links.
Message posted on 09 Dec 2025 11:01 AM
Apart from the free 150 number for Sky Talk and Sky Mobile customers, Sky do not allow phone numbers on the forum in digit format or written words. Any such posts would be removed.
Message posted on 09 Dec 2025 11:24 AM
@MMMIIIUUUT it takes under 10 seconds to an online search for a number for Sky Customer Services but only use numbers starting 03 to avoid call forwarding cowboys. All numbers go into thecsame IVR aks the bbot.
Message posted on 18 Dec 2025 01:40 PM
I NEED TO SPEAK TO SOMEOBE REGARDJNG MY LANDLINE WHICJMH IS £100 MORE EXPENSIVE THAN LADT MINTH AND IT IS NOT WORKING
Message posted on 18 Dec 2025 02:12 PM
See Post 5 for methods of contact. It sounds like you've been calling either premium rate numbers or a lot of calls on the Pay As You Talk tariff. The breakdown of your bill should give you a clue.
