30 Jun 2023 03:19 PM
Does the sky engineer need access to a communal aerial to connect broadband? Sky TV is being connected at a later date
30 Jun 2023 03:27 PM
Posted by a Superuser, not a Sky employee. Find out more@Mike62x Broadband does not get connected to the aerial. It is either connected via your phone socket or if you are having fibre installed then this is done by other means.
30 Jun 2023 03:28 PM
They may need access to any internal switching room/comms room to test the connection between your phone socket and the any internal switchboard.
Could you enter you full postal address below and post the table after removing your address from the image
30 Jun 2023 03:31 PM - last edited: 30 Jun 2023 03:31 PM
Sky broadband, like that from all similar ISPs, is delivered over Openreach copper or optical cabling.
'Satellite by internet' is a thing, but Sky is not a satellite ISP and typically a communal dish would not be suitable.
