Discussion topic: Broadband check shows problem with sky q box and WiFi but when checks are run it says all ok
This message was authored by: BigAnd
Sky app shows an issue with broadband connection with sky q box and with WiFi but when the fix issue is pressed it says all is ok?
Re: Broadband check shows problem with sky q box and WiFi but when checks are run it says all ok
@BigAnd  Is this the Sky Q router or the Sky Q box you watch your TV through? Are you also having issues with your broadband?
