Discussion topic: Broadband and wifi tested ok .. no internet.
This message was authored by: PeterC7
Devices are able to connect to wifi. Did a test to check broadband supply. Router has been rebooted.  Some devices find and connect to wifi.   The router test show 0 devices connected.  No Internet  on phones tablets or laptops.
This message was authored by: Harish2
Re: Broadband and wifi tested ok .. no internet.
Broadband working but internet is not connected and no devices are connected
I have tried twice router switched off and started again. Still no devices connected.
Avatar for PeterC7
Managed to solve with a call to support   but they recommended if it happens again, power down the router for 30 mins  as this will reset something fully, and  should have the same effect as the work they did.
