9
This discussion topic has been answered Discussion topic: Broadband and phone line
This message was authored by: powlee46
Phone regularly drops out cutting Broadband and setting Burglar Alarm dropped line signal off. FAQ s not helping, need a physical check.
Avatar for powlee46
This message was authored by: powlee46 Answer
Re: Broadband and phone line
Openreach called yesterday and replaced a socket which seems to have cleared the problem. Did think my Sky Router was bit outdated but that is another situation.
This message was authored by: peter-marlow+1966
Sounds  like  you  need to call sky and arrange  for  an engineer  to visit, we are all fellow customers on here
P c marlow
@powlee46
Have you run the online tests for your line to see if it finds any faults:
If this is of no help give Sky a call to report it to them.
@powlee46  Does this drop happen when you pick the phone up or putting the phone down?
Avatar for powlee46
Yes. Internet drops for a few minutes when landline is picked up.
@Highlinder check that either the hub is plugged into a prefiltered socket with two outlets or is using a working line filter typically your fault is caused by poor filtering. You can buy line filters cheaply from hardware stores etc.
@Chrisee  That is what I was going to ask next if the phone was connected to an external filter or into a filtered faceplate.
Avatar for powlee46
This message was authored by: Kerrycatling
In need of a socket for my kitchen
@Kerrycatling if you want a master socket moved call Sky and they will be able to sort it for you.
