Discussion topic: Broadband and WiFi not working
Message posted on 25 Sep 2025 09:19 AM
My broadband keeps dropping off showing an orange light last light I switch it he hub on and off sometimes I get a signal and broadband works for a short period of time it then drops off again
Message posted on 25 Sep 2025 09:30 AM
							Re: Broadband and WiFi not working
@Kieran101 You do not say what sky service you have, without that you can just run the two links below, start with the service checker and then the diagnostic!
Try running the line test here to see if any faults are found:
