3
This discussion topic has been answered Discussion topic: Broadband and WiFi not working
This message was authored by: Cantona77
It looks like a lot of Sky broadband users are having internet problems,I am also not getting any Internet AGAIN.....
Re: Broadband and WiFi not working
@Cantona77
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
@Cantona77
Avatar for Cantona77
Level 0 icon
I have run those tests and they say there's no problems,but there's no network connection,and this happens nearly every weekend for a couple of months now,thank you for your reply.
This message was authored by: Ricki187187
No helpmat.all.dignostic checks other person provided doesn't work as if not on system.so to speak even though logged int onapp.
Finding it all very tedious and **bleep** off already and only been with them.a DAY took over an hr to even get some woman on phone who was no help.sky had tech problems.so couldnt taken calls from 8.30am or whatever time it was until around10am or so.
At this rate.il be foing back to now.tvor talk talk
