4
This discussion topic has been answered Discussion topic: Broadband WiFi signal does not reach the whole of my house
This message was authored by: Mikesha90
Hi my WiFi signal doesn't reach the back of my house , having poor connection / no connection at all in some rooms further away form the router , does sky offer a free booster or advice on how to rectify this ?
Re: Broadband WiFi signal does not reach the whole of my house
@Mikesha90 Sky have a Wall to wall Wifi guarantee  but it is of limited use and they will try to sell you an upgade either to their Broadband Boost bundle at £5 a month which will get you a booster if you can't get 3Mb/s in every room. They also offer a new package called Wifi Max which has a speed guarantee of 10Mb/s in every room which increases ro 25Mb/s if you have the two fastest full fibre. Services. The max system gets you a new hub and up to 3 extenders if a Sky engineer agrees you need them.
Hiwever what many people do is to buy a third party wifi system and either replacectge Sky hub totally or turn off the hub's wifi and use their system as Access points. You will find most isps have similar deals as guaranteeing Wifi speeds which depend on factors like size and type of construction of the customers home and tge amount of interference from neighbours is a dodgy business.
@Mikesha90Did you just recently join Sky and finding that you  don't have enough coverage for Wi-Fi?
Avatar for Mikesha90
Sorry should have mentioned that I've had sky for 6 years and had this router for around 6/8 months without issue, my son has moved into one of the further back rooms of the house and as it was unoccupied before didn't realise it didn't have WiFi signal as we rarely went in there 🙂
This message was authored by: Samholli69
I'm a new customer and the internet works but not in every room. I have a Sky Max Hub.Do I need a booster or extender? And how do I get these please @ highlinder
