Discussion topic: Broadband/WiFi not working
Message posted on 13 Nov 2024 04:01 PM
1st and 3rd lights are green with 4th yellow. 2nd light not on. This has been down for over an hour and needs restoring as I work. from home
Message posted on 13 Nov 2024 04:12 PM
Re: Broadband/WiFi not working
@HO13 your hub has lost connection to the line. You can check if Sky are aware of a fault affecting your line by running the service check in the My Sky app. If thst doesnt indicatecthey are give them a ring to report it so they can get it checked out.
You are using a domestic line for work which is fine but doesn't change the service level for faults which is a fix within 2 working days after tge report ie if reported today by Friday evening. Openreach dont guarantee all faults will be fixed in that time but you get paid compensation if they aren't see Customer Auto-Compensation | Sky Help | Sky.com
