Discussion topic: Broadband Speed👎
This message was authored by Ged2wilson This message was authored by: Ged2wilson
Broadband Speed👎
MySky app INCORRECTLY shows speeds of 11mbs, & averaging 10mbs? The speeds on ookla show 1.26mbs & I presently cannot stream video's at all??
It is currently fluctuating between 0.6 - 2.9mbs!! And I am unable to stream at all!!
This message was authored by SKY1992bf This message was authored by: SKY1992bf
Re: Broadband Speed👎
@Ged2wilson  Have you reported this to sky?
note sky won't accept third party readings
Please note: I am just a sky customer not a employee - posts from sky employees are clearly marked as such
This message was authored by Mark39 This message was authored by: Mark39
@Ged2wilson the app show the speed being delivered by Sky to your Hub. A wired connection to your Hub should give speeds of around 10Mbps.
If you're connecting via WiFi your speed may be significantly less than that depending on WiFi conditions within your home.
That would be very poor for FTTC (and less than half what even ADSL is capable of on a short line) which suggests you are in a challenging location or using older technology.
If you post your Hub stats, we'll have some information about your particular phone line and internet connection to work with.
Note that it's speed arriving at the Hub which counts against the minimum speed guarantee, not speed test website results on a wireless device.
This message was authored by JPR007 This message was authored by: JPR007
@Ged2wilson The Sky app isn't wrong, it is reporting a different speed to the one Ookla measures.
The sky one reports your line speed, or "sync" speed. Ookla (in your case no doubt on a device connected via WiFi) is measuring the speed of the devices connection to the router, then to the internet. If the WiFi is suffering and is really poor, this incorrectly leads people to think the broadband is running much worse than it actually is.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Ged2wilson
@Ged2wilson
The 'PPPoA' shows that's ADSL2+ running at about half the maximum speed the technology is capable of, so presumably there's something like 2800 metres line distance to the telephone exchange.
ADSL is essentially obsolete these days, particularly as the outbound speed is inherently extremely limited.  If you try your address at https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome this should indicate if something better is available.
This message was authored by mae-3 This message was authored by: mae-3
@Ged2wilson
Note on the router stats that the system is downloading at about 9.2Mbps downstream at the time the router stats were taken and posted.
@Ged2wilson
You have a lot of traffic on your router for it only being up for 1.5hrs. I suspect whats happening is you have a busy house or a single device that is bandwidth heavy so whenever you try and use other devices or run a speedtest it looks like your connection is slow because you are trying to share a fairly low speed connection. Ideally you need to upgrade to fibre if its available to you.
I am NOT a Sky Employee
