5
This discussion topic has been answered Discussion topic: Broadband Speed not as stated by Sky
This message was authored by: GuyandNikki
I've run a broadband speed tests using my Sky app and what a surprise it shows an average of 37.5mps I've then run multiple tests on 2 laptops on various independent broadband speed test sites including Which and USwitch and they are showing speeds of approximately 17mps to 24mps I've noticed my speed has dropped considerably over the last couple of weeks, funny as Open reach have also just literally fulfilled their full fibre project in my town and I can now apply for full fibre products from multiple providers. Are Sky throttling their existing customers as a ploy to get them to upgrade?
This message was authored by: mae-3 Answer
Re: Broadband Speed not as stated by Sky
@GuyandNikki
You likely have a fault on the twisted pair to the FTTC cabinet, unfortunately, getting it fixed will be difficult and Sky may say the best course of action is to upgrade to full-fibre!
@GuyandNikki
@GuyandNikki as explained it is probably a coincidence certainly there is no evidence Sky throttle connections to encourage switching. However if you have access to full fibre it is worth upgrading as the connection will be faster if you stick with the 75Mb/s Superfast product you will get the full speed as full fibre has no appreciable speed loss between the exchange and your hub. Also you maybe able to get a lower price or get a higher speed if you upgade.
No: broadband provision is a regulated industry and an ISP wouldn't expect to be able to get away with that even if they were tempted.
Avatar for GuyandNikki
Sky say that I am still getting my guaranteed speed, however I have done multiple controlled tests using speed checks with wired and wireless connections and I can assure you the speed is certainly not what your stating.
Funny! You're encouraging me to upgrade which is exactly the type of sales ploy that I was implying!
This message was authored by: daveNOS
@GuyandNikki No one who has replied to you here is employed by Sky, so no sales ploy is being used it just makes sense to move to full fibre if its available as it far more reliable.
If Sky have run tests that show your router is connecting to the cabinet/exchange at a speed that is above the minimum guarantee then they will do nothing, the speed to your devices is not covered by that guarantee as there are far to many variables for that to be possible,
