Discussion topic: Broadband Setup
This message was authored by madhavcs This message was authored by: madhavcs
Broadband Setup
Hello There,
This is Madhav, the Broadband SKY HUB box delivery at my location is scheduled on 22nd July 2022 and the Engineer visit on 25th July 2022. Requesting you to complete entire setup or installation on 21st or 22nd July 2022 or 23rd July 2022.
This is the location:
Madhava S
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Broadband Setup
@madhavcs
You aren’t talking to Sky as this is primarily a customer helps customer forum so there’ll be no automatic contact from Sky as a result of you posting on here. It stands every chance that the installation date you have been given is the earliest available.
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Broadband Setup
@madhavcs
This forum is mainly customer to customer based, you are not talking to Sky here.
When you book your install the hub is sent a few days early to ensure it arrvies before the activation date. On activation day an engineer activates your line at the cabinet, this work is done by Openreach. When you placed your order the earliest available date would have been given to you so trying to change it now will likely just delay your install further.
I am NOT a Sky Employee
Re: Broadband Setup
@madhavcs  That's just not going to happen I'm afraid,  if you have been given a date of the 25th for broadband then that will be the earliest date available.
