Discussion topic: Broadband Outage 23 January 2025
Message posted on 23 Jan 2025 06:23 PM - last edited: 23 Jan 2025 06:28 PM
Thread created to reflect current outage
Message posted on 23 Jan 2025 05:20 PM
Internet not working
My internet stopped working at 16:50 tonight and not sure why
WiFi down
Message posted on 23 Jan 2025 05:22 PM
Re: Internet not working
Mine too. Where are you based? My reboot is producing only 2 green lights on one orange on the router
Message posted on 23 Jan 2025 05:23 PM
@Daniel48
Message posted on 23 Jan 2025 05:25 PM
Re: WiFi down
I have the same problem
Message posted on 23 Jan 2025 05:26 PM
Re: WiFi down
@Ash3000 @Karenocon First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 23 Jan 2025 05:27 PM
Mine too. Two green lights, one orange and one out completely. Sktchecker says everything is OK. I am based in St Margarets London.
Message posted on 23 Jan 2025 05:29 PM
Re: WiFi down
It's not showing a link to book an engineer either, absolutely hate calling Sky too!
Twickenham - same on reboot two green and one orange light
Twickenham, London - same issue, same orange light on Internet, servuce checker says no problems. Down since 16:50.
Message posted on 23 Jan 2025 05:33 PM
Same issue here, ran all diagnostics several times, sometimes comes up amber with "let's improve your speed", sometimes it says diagnostic service doesn't work. Probably something to do with the storm but I'm down in London, not that bad weather here yet.
Overall diagnostics seem a bit useless since by the end I am always connected even though I'm not.
Message posted on 23 Jan 2025 05:35 PM
I am having the same problem and in Richmond lock near st Margaret's
Message posted on 23 Jan 2025 05:36 PM
Same . WiFi stopped working . St Margarets area
1 green light (power) and 1 orange (voice). Internet light off
