Discussion topic: Broadband Dropping out - eth3.1 - WAN link DOWN.
This message was authored by: twistedmonkey
I have Fibre broadband and every so often my WAN link drops (internet light orange), to bring it back I need to unplug and reconnect the uplink to the ONT, which restores service.
I would not mind, but it does NOT automatically reconnect. I either have to reboot my hub, or physically reconnect the ethernet port to the ONT. Using the webUI to disconnect and reconnect always fails to restore connectivity.
I've seen this at least 3 times so far since I was connected on the 3rd April, and for the last 3 I collected logs from the router, and in each case there was no error before the link going down.
2024-04-22   10:21:51 syslog: [273968.949000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
* 2024-05-09   01:52:52 syslog: [687205.219000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
* 2024-05-30   20:59:42 syslog: [2570393.556000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
On the 22nd I restored service by rebooting, since then I have just disconnected the ethernet cable in port4 and service has come back.
Is there any fix for this?
Manufacturer Sky
Model SR203
Firmware Version 7.03.0704.R
DSL Firmware Version A2pvfbH043p1.d26u
Re: Broadband Dropping out - eth3.1 - WAN link DOWN.
@twistedmonkey   Please can you post your router stats so the forum can advise on any issues. This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
Avatar for twistedmonkey
I doubt they will help that much. it just shows I'm using the WAN and LAN interfaces.
I shared them last night, and tonight but something seems to be deleting my reply (which is just a copy/paste of the stats.
Will try again.
heres the logs from the recent disconnect. Public IPs and mac-address removed.
19:29:16 syslog: WAN IPV6 UP
19:39:17 syslog: Send out NTP request to ntp1.isp.sky.com
19:39:17 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
19:39:17 syslog: System time is up to date
19:53:32 syslog: Lease renewed 3600 ip x.x.x.x
19:59:16 syslog: WAN IPV6 UP
20:18:27 syslog: Lease renewed 3600 ip x.x.x.x
20:29:16 syslog: WAN IPV6 UP
20:43:39 syslog: Lease renewed 3600 ip x.x.x.x
20:54:29 syslog: [2570081.014000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
20:54:31 syslog: eth3.1 - WAN link DOWN.
20:54:31 syslog: DHCP lease expired from server. Connection DOWN.
20:54:32 syslog: [2570084.059000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
20:54:36 syslog: Voice IP Connection Down
20:54:39 syslog: Voice Disconnected
20:59:01 syslog: WAN disconnection request from user through GUI
20:59:03 syslog: WAN connection request from user through GUI
20:59:43 syslog: sky dhcpc client (v0.0.1) started
20:59:47 syslog: [2570398.594000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
20:59:48 syslog: sky dhcpc client (v0.0.1) started
20:59:56 syslog: sky dhcpc client (v0.0.1) started
21:00:02 syslog: eth3.1 - WAN link UP.
21:00:02 syslog: Received valid DHCP lease from server. Connection UP.
21:00:02 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D21023BC005390/fake-mac-address/x.x.x.x/7.03.0704.R/2a02:c7c:xxxx:xxxx::1]
21:00:13 syslog: WAN IPV6 UP
21:00:13 syslog: Voice IP Connection Up: 2a02:c7c:xxxx:xxxx::1/64
21:00:13 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D21023BC005390/fake-mac-address/x.x.x.x/7.03.0704.R/2a02:c7c:xxxx:xxxx::1]
21:00:15 syslog: Voice Configured
21:00:19 syslog: Voice Initialized
21:00:19 syslog: Voice Connecting
21:00:20 syslog: Voice Connected
@twistedmonkey you are right the stats dont show much but can I suggest you power down the hub for 30 to 45 minutes? This may help in two ways first the hub has been running for over a month and may have a minor issue due to a memory leak. The other reason with any luck that will switch the port on the server Sky are using for your connection which is a more likely cause.
If that doesnt report the fault to Sky but I suspect they wont know what to do either. Best of luck.
