Discussion topic: Broad band wifi
Message posted on 18 Oct 2025 01:05 PM
							Broad band wifi
Hi, my wifi isn't working but the checks say no problem can you help
Message posted on 18 Oct 2025 01:16 PM
							Re: Broad band wifi
@Carl109
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
If you’re still having problems you may need to contact Sky to report it.  The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
