Discussion topic: Briadband/wifi not working
Message posted on 20 Nov 2025 09:32 AM
Message posted on 20 Nov 2025 09:44 AM
Re: Briadband/wifi not working
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 21 Nov 2025 09:33 AM
our Broadband speed has dropped in the last two days to approximately 2mb from 14.7mb and rendered the WiFi unusable. We have done all the necessary checks on line and we have disconnected and reconnected our router but it makes no difference. A family member who lives nearby is also experiencing the same problems. It seems that this is an area issue.
Message posted on 21 Nov 2025 10:48 AM
@TheClose With such low speed to start with are you on a old ADSL connection far away from any potential FTTC cabinet, would be best to contact sky, they can take a look see why it's so far down!
