Discussion topic: Briadband down 00.25 box out no internet
This message was authored by: Joy44
New max fibre router on red, bt box out also
Re: Briadband down 00.25 box out no internet
@Joy44
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
